TallDavid
Oct 17, 2014Initiate
WD60EFRX WD Red 6TB For ReadyNAS104?
Fry's has started offering the WD 6TB Network NAS HDD SATA 6Gb/s 64MB Cache for $239. I know this new drive is not on the official compatibility list. Will the RN104 support 6TB drives? If so, how...
Jan 31, 2015Guru - Experienced User
4x6TB RAID-5 is a little over the 16 TiB limit, and the ReadyNAS does not let you create multiple volume on the same disks.
RN104Owner wrote: To maximize the 16TB volume size can you use 4 - 6TB drives? That would give 16.34TB in a raid 5. Could the extra be made available as another volume?
If you want 4x6TB RAID-5, then you need to step up to the RN200 series or better.
