Jobbigvolvo
Aug 01, 2014Aspirant
WD60EFRX WD red in Ultra4+ ?
Time to upgrade my trusty old Ultra4+. ATM its running 4TB red disks and im eyeing the new WD60EFRX. But there seems to be a total lack of info on compatibility from Netgear. Surelly they have a fe...
mdgm-ntgr
Aug 02, 2014NETGEAR Employee Retired
Hi Jobbigvolvo,
Thanks for the feedback.
What version of RAIDiator?
Are you using X-RAID2?
Note that you can't expand beyond 16TB. You have to do a factory default with that capacity in place. Our new devices running ReadyNAS OS 6 do not have this limitation.
