Jobbigvolvo
Aug 01, 2014Aspirant
WD60EFRX WD red in Ultra4+ ?
Time to upgrade my trusty old Ultra4+. ATM its running 4TB red disks and im eyeing the new WD60EFRX. But there seems to be a total lack of info on compatibility from Netgear. Surelly they have a fe...
mdgm-ntgr
Aug 02, 2014NETGEAR Employee Retired
I would think the 6TB drives should work, however if you run into issues using drives not on the compatibility list support won't be able to help.
