ukbobboy's avatar
ukbobboy
Luminary
May 03, 2016
Western Digital new 8TB Red HDD
Dear Forum Members   I'm sure most of you have heard that WD have released a new 8TB Helium Filled Red HDD, does anyone know if there is a ReadyNAS that can utilise this drive?     UK Bob
  • StephenB's avatar
    May 05, 2016
    ukbobboy wrote:
    Therefore, as it looks as if the laser enhanced HDs have been abandoned (or at least temporarily shelved), so will we now see helium filled HDs as the next generation of petabyte HDs (I believe 1PB = 1000TB)?
    Last time I checked HAMR was still the long-term solution, with the first commercial disks expected sometime in 2018.  At least that is Seagate's marketing messaging.  Now that Seagate also has helium, it will be interesting to see if WD starts chatting up HAMR more.
    Don't expect petabyte capacities any time soon - perhaps 100 TB by 2025.  Helium is likely a short term play (unless there is a way to use it advantageously with HAMR),
    I suspect that it's difficult for the manufacturers to figure out the right balance between SSD R&D and mechanical drive R&D.
    However, the "new kid on the block" seems to be helium filled HDs, which you say you have ordered a couple.
    Yes.  Currently my RN202 has 2x6TB jbod, and my RN102 has 2x3TB jbod.  Both are for backup.  The RN102 isn't large enough, so it is part of a NV+, Duo, RN102 backup combo.
    The plan is to set up both OS6 NAS as 8 TB + 6 TB jbod, and set aside the 3 TB drives in the RN102 as spares for my Pro-6.  That will let me retire the old v1 platforms as their disks fail.
    I'll post back on how it goes - the disks should arrive Saturday, and it will take a while to get everything installed.  I might do a factory reset on the RN202 while I am at it.
ProSupport for Business
