PeteCress
Jul 08, 2015Apprentice
Western Digital Red 4 TB: Any Hope for Ultra-6 HCL?
Right now, the only 4TB drive I see on the HCL for Ultra-6 is the Hitachi. The WDs, of course, being significantly cheaper....
Jul 08, 2015Guru - Experienced User
There are two limits, and they both apply to the actual volume size, not the raw disk capacity.
One limit is that you can't expand from < 16 TiB to > 16 TiB in any circumstances. You could get 20 TB in the ultra-6 anyway (single redundancy) by doing a factory reset with all drives in place. Or 16 TB with dual redundancy. Further expansion is not possible.
The other is that a volume cannot grow more than 8 TiB from its starting point. So if you started with 2x1TB on your initial install you'd have a 1 TB volume starting point. The growth limit would take you to a bit more than 9 TB. So you wouldn't get to 14 or 16 in that case. I don't know what you actually had installed when you did the original installation, so I don't know what your actual growth limit is.
