PeteCress
Jul 08, 2015Apprentice
Western Digital Red 4 TB: Any Hope for Ultra-6 HCL?
Right now, the only 4TB drive I see on the HCL for Ultra-6 is the Hitachi. The WDs, of course, being significantly cheaper....
Jul 08, 2015Guru - Experienced User
Try downloading the logs, and looking in expansion.log for the first occurrence of "Data volume has been successfully expanded". If the date matches your first install that should tell you.
If you did start at 6x2TB dual redundancy, you can expand up to 16 TiB, so 6x4TB should be fine.
But unfortunately dropping back to single redundancy means a reset.
