Chris_Boston
Jun 26, 2012Aspirant
What exactly is transcoding?
Hi, I'm looking to dive into ReadyNAS and get all of my pictures and music somewhere central so they're shared across all of my devices. As a bonus, and something I don't do today, I'd also like t...
Jun 26, 2012Guru - Experienced User
It's a bigger deal for video. Most portable devices support AVC (H.264)'s constrained baseline profile, and many also support H.263/mpeg 4 ("xvid")
However, there are a lot of non-compliant H.264 MKVs floating around. And a lot of other codecs (DV, Motion JPG, VC1, VP8, Theora in use ). Also, these files might also need audio transcoding (for instance ogg is not supported on many mobile devices).
However, you don't necessarily have to use real-time transcoding. Another option is to convert your media offline into something your devices can play.
