Chris_Boston
Jun 26, 2012Aspirant
What exactly is transcoding?
Hi, I'm looking to dive into ReadyNAS and get all of my pictures and music somewhere central so they're shared across all of my devices. As a bonus, and something I don't do today, I'd also like t...
Chris_Boston
StephenB wrote: However, there are a lot of non-compliant H.264 MKVs floating around.
I'd be ripping my own DVDs, so I suspect I'm not worried about things that are "floating around" since I'd be able to control the format I suspect (but I'm new to this...)
StephenB wrote: However, you don't necessarily have to use real-time transcoding. Another option is to convert your media offline into something your devices can play.
Thank you - this line helps clarify a ton for me. It sounds like so long as I rip into a format that the players support, I'd be fine. This wasn't the way my mind was working - I was thinking that some devices just weren't going to stream, but I guess that's not really the case.
