Chris_Boston
Jun 26, 2012Aspirant
What exactly is transcoding?
Hi, I'm looking to dive into ReadyNAS and get all of my pictures and music somewhere central so they're shared across all of my devices. As a bonus, and something I don't do today, I'd also like t...
Jun 26, 2012Guru - Experienced User
Yes. An MP4 container with AVC video and AAC LC audio should play on your iPAD just fine (and also on your Android devices). The other aspect is to choose a file size / bit rate which fits your NAS and network, as well as giving you reasonable quality. You likely will need to experiment a bit with the first couple of DVDs, but once you find a working recipe it will become routine.
Chris-Boston wrote: It sounds like so long as I rip into a format that the players support, I'd be fine.
