HomeNASUser2020
Apr 11, 2020Aspirant
What is the UPS model that will allow automatic shutdown on threshold for RNDX4220|ReadyNAS NVX
Model: RNDX4220|ReadyNAS NVX 4TB According to the manual : When an APC-brand UPS is connected, a shutdown on threshold drop-down option is available. Does this mean I am able to use ANY m...
Apr 11, 2020Guru - Experienced User
HomeNASUser2020 wrote:
Also do you know what power measurements this device uses on regular basis so i could use the APC battery backup selector tools below to determine the APC device to purchase based on how long it will keep the NVX running?
The hardware manual is here: http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf
On page 39 it says: NVX Pioneer and NVX (Business Edition): 76W (with 4 x 1 TB disks).
FWIW, I use a CyberPower UPS that is rated at 1350VA.
Does this mean I am able to use ANY model apc battery backup or does it need to be a smart ups model?
You need a model that includes a USB connector for monitoring. The Network UPS Tools folks maintain a compatibility list here: https://networkupstools.org/stable-hcl.html
Sandshark
Apr 12, 2020Sensei
For the NVX or other systems that still run older firmware, the list at the NUT site might include ones not supported by the older version of NUT that's in the firmware. There are notes about the min revision of NUT for some UPS, but I don't know which version is in the 4.2.x firmware.
- StephenBApr 12, 2020Guru - Experienced User
4.2.31 runs version 2.0.5.
- HomeNASUser2020Apr 12, 2020Aspirant
So I am currently running RAIDiator 4.2.31.
So what i will need to do to get this to work is using a PC that is directly connected to any USB port on the NVX and then install this NUT software on the PC and then configure the NVX to shutdown on threshold in the NVX web gui?
Also thank you both for your helpful answers!
- StephenBApr 13, 2020Guru - Experienced User
No. You'd connect the UPS directly to the NAS USB port. The NAS already has the NUT software installed. The NAS will automatically detect the UPS when you connect it. Shutdown will be set to "Auto" by default. Whatever other configuration options are available with your particular UPS will be shown in Frontview (in System->Power).
FWIW, I use a CyberPower UPS with my own Pro-6 (also running 4.2.31), and I do see threshold settings in Frontview. Though personally I just use Auto.
While it is quite possible that some new UPS models might not work correctly with the older NUT software on the NAS, I haven't seen any reports of that happening here. APC is a popular brand, and many NAS owners use them.
