aaseef021's avatar
aaseef021
What port is ReadyNAS configured for, can I change it
What is the default port for ReadyNAS 516, can I change the port if so what is the range?
  • aaseef021 wrote:
    I mean by when you access it via IE or chrome. IP / port?
    It uses the normal HTTP/HTTPS ports of 80 and 443.
    You'll see a way to set up a second HTTPS port in system->settings->services->HTTP.  If you can to use that second port then you need to include it in the browser URL.
    I am wondering why you are asking.
  • StephenB's avatar
    Not sure what you mean.  Are you talking specifically about ReadyCloud?  If not, what protocol?
    • aaseef021's avatar
      aaseef021
      • StephenB's avatar
ProSupport for Business
