nrobinson1's avatar
nrobinson1
What to replace ReadyNAS NV+ v1 with
Hi All,
So my NV+ v1 just had the PSU go boom... when I searched on the forums it seems there is a work around by re-wiring anATC Power Supply, but not sure I'm up for this, and it is an opportunity to upgrade to a newer model...
So first and formost I am looking for a replacement for the NV+ that has 4 bays, and when I plug my old disks in, it will recognise them and I won't have to rebuild the complete array. (I have 4 x DT01ACA100 Toshiba 1 TB SATA Internal Hard Drive, 3.5in, 7200 RPM).
Second thing is that if the new NAS could run PLEX server that would be a great bonus.
Thanks in advance.
Nik.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    nrobinson wrote:
    I was using X-Raid.
    Then you can get either the 104 or 204 if you wish.
    If you do get a new ReadyNAS it is important not to insert the disks into the NAS until prompted to by support.
  • I appear to have just joined the "blown NV+ v1 club" but I'm not tech-savvy enough on my own to open this thing and see what exactly is fried inside.
    How can I learn more about a data migration plan to a new (yet-to-be-purchased) box. Or perhaps someone has an old working NV+ v1 they'd be willing to lend or sell used so I can move the disks myself? I just can't envision trying to fix this box.
    Thanks all.
    -Motts
ProSupport for Business
