rmacbeth
Aug 19, 2016Apprentice
What would be the best setup for Raid with 4 bay NAS
With the 4 bays what would be the best setuo for Raid? Also with the WD red what version should I get the reg red or the pro. I looking at either 4 2TB drives or 4 4TB drives. The cost difference c...
- Aug 23, 2016
You can't make LAGs on the GSS108E but you can make static LAGs on the GSS116E. Neither of them support LACP LAGs.
http://www.downloads.netgear.com/files/GDC/datasheet/en/Click-Switch.pdf
If you really want to make a LAG, you could create a static LAG on the GSS116E and a Round Robin bond on the NAS, which would be the correct configuration.
Unless you have a good reason to think so, using an LACP LAG between the NAS and GS108T, then a static LAG between the GS108T and the GSS116E is not going to have any benefit over simply using a direct static LAG.
I personnaly avoid ALB, but that's only my opinion ;)
Aug 21, 2016Guru - Experienced User
rmacbeth wrote:
The question I still have is with the RN214 Link aggregation will the GSS116E LAG configurantion be able to use for this?
I don't think the GSS116E supports LACP - if that is correct, then you won't be able to use the GSS116E LAG.
You can still try to use the ALB bonding mode in the RN214 - that doesn't require special switch support. Sometimes it does misbehave - if you see odd behavior, disconnect the second NIC and just to make sure its not related to bonding.
rmacbeth
Aug 21, 2016Apprentice
StephenB I heard that might be a problem. I take it that the GS108T would be a good fit. I can get one for approx $80 and put it in frount of the GS116E.
Thanks so much for all your help
Rich
- StephenBAug 21, 2016Guru - Experienced User
The GS108T does support LACP. You'd need a static lag between the GS108T and the GSS116E, and LACP between the GS108T and the RN214.
You will only see a performance benefit if you have multiple simultaneous connections from devices on the GSS116E (or GS108T) and the NAS.
I'd probably wait on the GS108T and try ALB first.
- rmacbethAug 21, 2016Apprentice
StephenB Would it be worth trying to use ALB with using the LAG on the GS116E or would it be not worth trying?
Thanks
Rich
No, that's not the correct way to configure it. You set up the NAS normally (1 network connection). Then connect the second NIC, and configure ALB on the NAS. No LAG is configured on the GS116E.
