rmacbeth
Aug 19, 2016Apprentice
What would be the best setup for Raid with 4 bay NAS
With the 4 bays what would be the best setuo for Raid? Also with the WD red what version should I get the reg red or the pro. I looking at either 4 2TB drives or 4 4TB drives. The cost difference c...
- Aug 23, 2016
You can't make LAGs on the GSS108E but you can make static LAGs on the GSS116E. Neither of them support LACP LAGs.
http://www.downloads.netgear.com/files/GDC/datasheet/en/Click-Switch.pdf
If you really want to make a LAG, you could create a static LAG on the GSS116E and a Round Robin bond on the NAS, which would be the correct configuration.
Unless you have a good reason to think so, using an LACP LAG between the NAS and GS108T, then a static LAG between the GS108T and the GSS116E is not going to have any benefit over simply using a direct static LAG.
I personnaly avoid ALB, but that's only my opinion ;)
Aug 21, 2016Guru - Experienced User
rmacbeth wrote:
StephenB Would it be worth trying to use ALB with using the LAG on the GS116E or would it be not worth trying?
No, that's not the correct way to configure it. You set up the NAS normally (1 network connection). Then connect the second NIC, and configure ALB on the NAS. No LAG is configured on the GS116E.
