rodenas
Jul 08, 2012Aspirant
What's the exact recognized size in a 3TB drive?
Hi all, I've got a DuoV1 and I'm planning an upgrade to a DuoV2 in the future. But I'd like to change first a failing 2TB disk. If a buy a 3TB disk and use it in the DuoV1, will it be recognized as...
Jul 08, 2012Guru - Experienced User
The V1 doesn't support 3 TB drives. I think you get about 766 GB available space if you try to use one.
