rodenas
Jul 08, 2012Aspirant
What's the exact recognized size in a 3TB drive?
Hi all, I've got a DuoV1 and I'm planning an upgrade to a DuoV2 in the future. But I'd like to change first a failing 2TB disk. If a buy a 3TB disk and use it in the DuoV1, will it be recognized as...
rodenas
OK, thanks. Do you know if there is a way to set the drive into a kind of compatibility mode? (like it used to be with the 32GB or 128GB limits, if I remember well, and configurable by a jumper in the hard drive). Or use the aforementioned MBR method instead of GPID.
Thanks again.
Thanks again.
