Skeetboy1
Apr 26, 2018Apprentice
When will we find Hard Disks WD RED 10TB and 12TB on Compatibility List? ReadyNas 516 & 314
I have 2 clients running 2 x 10TB WD Gold drives in ReadyNAS 524x and 716x boxes, no problems so far other than a faulty disk at purchase (swapped without question). Both boxes currently running 6.9....
Marc_V
May 01, 2018NETGEAR Employee Retired
Hi Skeetboy1
NETGEAR does really put the drives on stringent tests to make sure that it is working with the ReadyNAS models available and list it as a suggested drive.
There are times though that the engineers might not be able to cope up with the release of new drives due to the time it takes to fully test a drive into ReadyNAS models and that is one reason not all models are getting listed right away (there are lots of drives available). Also, the HCL is like more of a suggested list of drives that NETGEAR was able to test.
If it was me I would go for the 12TB Gold. I'm pretty sure there are members as well who have tried using the drives without issues and the 10TB model is already listed which is the same series as 12TBs.
I have inquired about this and I hope they can check on the drive and get it listed. Though testing does take time so we have to wait but we can say it will be listed :)
Hope this helps!
Regards
