Clarkson
Feb 04, 2014Aspirant
Which drive
Hi all There are 24 approved drives for my nas rn312 . Can someone suggest which ones to look at need 2tb at least. Mainly for home media use photos music video etc. And anyone know any good deals...
xeltros
Feb 05, 2014Apprentice
I'm also happily running with Seagate NAS HDD (ST4000VN000). They are a little more expensive than the standard version but what you will spend you will get it back on the power bill. The extended warranty and their thermal performance are other advantages compared to normal disks.
I heard WD green drives had problems with their heads parking too often. There are utilities to change that. I don't know about WD red versions.
