Kimius
Jul 02, 2011Aspirant
Which drives to get for new ReadyNas?
So I need a new NAS. This is going to be expensive... TL:DR at bottom of post A bit of background info first. I have an NVX Business edition that I've had for a little over 2 years. I got it wit...
Kimius
Jul 03, 2011Aspirant
I would like to do a test of the drives, but that is made more complicated by my NV+ having less space than my NVX BE and my collection of data being bigger than either unit can handle. As it stands I've had to keep some shares exclusive to the NV+, some exclusive to the NVX BE, with only the most important being synced between both. This is why I need new drives.
Once I find a way to get a backup of all my stuff off the NVX BE I will try to test the drives, but that might take a while to work out.
As for RSYNC, I'm assuming that would be the built-in backup task scheduler? I am already running that for my important stuff, and will use that for all my shares once I have the disk space.
