Kimius
Jul 02, 2011Aspirant
Which drives to get for new ReadyNas?
So I need a new NAS. This is going to be expensive... TL:DR at bottom of post A bit of background info first. I have an NVX Business edition that I've had for a little over 2 years. I got it wit...
Kimius
Jul 04, 2011Aspirant
PapaBear wrote: The consumer class drives are more prone to failure, but use in Raid5 use will not cause a failure.
That's all I needed to know. Seems I will need to get some enterprise drives then.
WhoCares? wrote: This sounds like sectors are being reallocated by one or more of the drives. You may be able to verify this by checking your log files.
The log files show no increase in reallocated sectors. That's one of the first things I check.
