Kimius
Jul 02, 2011Aspirant
Which drives to get for new ReadyNas?
So I need a new NAS. This is going to be expensive... TL:DR at bottom of post A bit of background info first. I have an NVX Business edition that I've had for a little over 2 years. I got it wit...
Kimius
Jul 16, 2011Aspirant
Perhaps I should have mentioned this before, but the examples I gave are for trying to access a different NV+ over CIFS. I have yet to try copying to/from a windows pc using frontview.
Also, the slashes that get added when using IE9 and 4.1.7? I tried to add in details without any slashes before the IP, and frontview added 3. Hence the line:
192.168.0.10/test = error message "Error connecting to ///192.168.0.10/test"
It should be noted that frontview has no problems actually performing the backup, as long as I create the backup job in Firefox.
