Kimius
Jul 02, 2011Aspirant
Which drives to get for new ReadyNas?
So I need a new NAS. This is going to be expensive... TL:DR at bottom of post A bit of background info first. I have an NVX Business edition that I've had for a little over 2 years. I got it wit...
Grievous
Jul 18, 2011Aspirant
Discussion of when what was released by who when what else was in beta aside and getting back to the issue at hand...
The missing backup options(vault and time machine) are something that I find to be strange. You also cropped out the actual browser so we can't spot whether or not some strange toolbar/app/whatever is installed that might be doing something.
First, re-install the firmware. I haven't seen any mention of that being done yet.
Second, exactly what version of IE9 are you running? You can find that under "about" on IE9's menu icon to the right side of the screen. With 9.0.8112.16421 running here it works fine for me.
Third, is this a 32 bit version of windows or a 64 bit version? We have seen differences with IE in the past during beta however I haven't heard of any problems recently(compared to IE8).
