NilsG
Aug 06, 2013Aspirant
Which gigabit netgear switch is best for jumboframes ?
I now have three GS608 v3 (gigabit and 9000 jumbo support) that seems to do the job well - is there better alternatives that will handle jumboframes better and give faster transfers ? (Before I had ...
Aug 06, 2013Guru - Experienced User
I am thinking there is no need to replace the GS108s unless you are seeing some evidence that something needs fixing.
What speeds are you getting now? Are the switches co-located?
