NilsG
Aug 06, 2013Aspirant
Which gigabit netgear switch is best for jumboframes ?
I now have three GS608 v3 (gigabit and 9000 jumbo support) that seems to do the job well - is there better alternatives that will handle jumboframes better and give faster transfers ? (Before I had ...
NilsG
StephenB wrote: I am thinking there is no need to replace the GS108s unless you are seeing some evidence that something needs fixing.
What speeds are you getting now? Are the switches co-located?
This is transfer to/from local PC with 6x SSD's (560/535MB/s read/write spec. Corsairs) on Areca 1680IX in raid0 and Intel Pro/1000CT - not very satisfied with the "hacky" upload
