NilsG
Aug 06, 2013Aspirant
Which gigabit netgear switch is best for jumboframes ?
I now have three GS608 v3 (gigabit and 9000 jumbo support) that seems to do the job well - is there better alternatives that will handle jumboframes better and give faster transfers ? (Before I had ...
Aug 07, 2013Guru - Experienced User
It seems unlikely that a switch would behave differently in the upload vs download. All transfers through the switch look pretty much the same (and involve both an upload link and a download link).
Can you bypass the switches and directly connect the two PCs? (manually configuring the IP addresses). That would let you know if the switches and cabling are to blame.
If they are, I'd look at the cabling first, I'd also try different switch ports.
BTW, what performance are you getting with jumbo frames off?
