NilsG
Aug 06, 2013Aspirant
Which gigabit netgear switch is best for jumboframes ?
I now have three GS608 v3 (gigabit and 9000 jumbo support) that seems to do the job well - is there better alternatives that will handle jumboframes better and give faster transfers ? (Before I had ...
Aug 08, 2013Guru - Experienced User
Writes to a Raid array require more I/O (which slows things down) but can be queued (which can speed things up).
NilsG wrote: Just wonder - can slower reads vs writes be due to the nature of x-raid2 ? and not to forget the disks - spinning disks are slower on writes
EDIT_ IS my ultra6 slow ? or is this speed what I can expect ?
Do you test with the settings I suggested (disk caching on, and journaling disabled)?
