NilsG
Aug 06, 2013Aspirant
Which gigabit netgear switch is best for jumboframes ?
I now have three GS608 v3 (gigabit and 9000 jumbo support) that seems to do the job well - is there better alternatives that will handle jumboframes better and give faster transfers ? (Before I had ...
Aug 18, 2013Guru - Experienced User
The 850 down seems about right, the 520 up seems a bit slow. Not horrible performance, but I'd expect something a bit faster. Are you perhaps using dual-redundancy?
