samuk
Oct 19, 2011Aspirant
Which HDD for my Ultra4
Hi, I needed something quite and energy efficient, speed would be good as i dont want anything too slow. I was thinking of the Green 2TB HDD's, though these are 5400rpm..will this be too slow? ...
Oct 19, 2011Guru - Experienced User
Folks are using this drive successfully. Though it is not presently on the hardware compatibility list, which means that you won't get Netgear support on disk-related problems. Netgear hasn't said if the drive has issues, or if they simply haven't tested it. Personally I wish they would as the older EARS (which is on the list) is no longer being produced.
The HCL is found here: http://www.readynas.com/?page_id=82
There might be a slight slowdown with a 5400 rpm drive, though in practice the disk transfer speed is very close to what you can get on a single gigabit connection anyway.
