Pinkyg
Dec 14, 2016Apprentice
Which routers support Link aggregation with RN214
Hi Folks, I'm considering purchasing a new router and thought it would be good to make use of the 2nd ethernet port on the NAS whilst I'm buying kit anyway. Is there a list of routers that wo...
- Dec 14, 2016
http://kb.netgear.com/29842/How-do-I-enable-LACP-on-my-ReadyNAS
The R8300, R8500, and R9000 all include LACP. Or you can use any Netgear Smart switch or managed switch.
Dec 14, 2016Guru - Experienced User
Pinkyg
Perfect Stephen, many thanks!
