DOA
Oct 05, 2011Aspirant
Why can't I get support? Ticket 16849963
here are the facts: 1) June 14 2011 bought new NV+ and 4 Barracuda 2TB HD from Fry's, checked compatibility list they should work. 2) Spent a week setting it up and some other equipment. Mixed Windo...
yoh-dah
Oct 18, 2011Guide
DOA wrote: Almost a week now with direct connect to the laptop with bridge to my home network. I am using the same cable I used when the NV+ was connected to the switch. No problems other than SSLLOOWW file access.
What should I try next?
Take a look at the network errors in FrontView's Network page. See if the counts keep growing even with direct-connect, or whether the counts remain pretty stable. Then compare this when you've connected the ReadyNAS to your switch/router. The best way to diagnose the problem is to introduce each new device to the network one at a time and see which one causes the problem.
