pearson
Apr 12, 2018Aspirant
Will I drop ISCSI connection during Firmware Upgrade
I need to performe an upgrade to our readynas but have several ISCSI drives conected to production servers. When I performe the upgrade will all the connections drop? If so for how long? Thanks ...
- Apr 12, 2018
The NAS needs to reboot as part of the process, so you will lose the connections. My RN526 took about a minute to reboot when I installed 6.9.3 (upgrading from 6.9.2). If you are upgrading from older firmware, it could take longer.
Apr 12, 2018Guru - Experienced User
- pearsonApr 12, 2018Aspirant
OK. Thank you for your reply. I will schedual an adequate down time for the upgrade.
- mdgm-ntgrApr 12, 2018NETGEAR Employee Retired
We do have a general guide: ReadyNAS OS 6: Firmware Upgrade Guide and Tips
If you have an older model the advice is mostly applicable (but the GUI and the volume maintenance options will be different).
Normally the update should go smoothly as StephenB described, but it's always best to be prepared just in case as you would with any other production system.
