EminiTrader
Mar 20, 2016Aspirant
Will this work for me?
HI All, I am going to purchase the R/N 214 with 4 bays. I am looking on the HCL and they show a Desktar Drive by Hitachi. The only Deskstar drives I find are made by WD. Here's a link to what I...
- Mar 20, 2016
HGST used to be Hitachi, but later got sold off to Western Digital. The drives should work, and most reports on deskstar drives here have been positive. Other good choices are WDC Red and WDC Red Pro.
Starting three drives is certainly viable, but it would be more economical to go with 2x4TB drives. Not only is the initial outlay less, you have more room for expansion later.
Mar 20, 2016Guru - Experienced User
- EminiTraderMar 20, 2016Aspirant
Thanks Stephen - I'm going to do it just like that!! I appreciate the response!
- saf1Mar 26, 2016Aspirant
Personally speaking the WD reds are great drives. Any manufacture that lists NAS storage as its primary role is a good choice. From there it comes down to price and performance - comfort more or less. Your choice. I have had great success using WD Reds 2 TB and recently over the past few months upgraded to the WD 6 TB reds.
- StephenBMar 26, 2016Guru - Experienced User
I use WD Reds myself, and have been pleased with them.
