TeknoJnky
Nov 27, 2012Hero
[wish] Factory default while keeping data
Something the entire readynas line really needs is a safe and supported way to factory default without losing the data volume. Yes, I am well aware of ways to do it and have done it, but it needs t...
ReadySECURE
Dec 04, 2012Apprentice
Are you ultimately asking about the OS reinstall function, the one that rewrites the OS onto the OS partition? That does not harm data as long as there are no other underlying problems like channel failure or disk failure.
