TeknoJnky
Nov 27, 2012Hero
[wish] Factory default while keeping data
Something the entire readynas line really needs is a safe and supported way to factory default without losing the data volume. Yes, I am well aware of ways to do it and have done it, but it needs t...
TeknoJnky
Dec 04, 2012Hero
readysecure1985 wrote: Are you ultimately asking about the OS reinstall function, the one that rewrites the OS onto the OS partition? That does not harm data as long as there are no other underlying problems like channel failure or disk failure.
yes, essentially reformatting /md0 and reinstalling from firmware, while keeping /c/c
this would return the system to the factory defaults, clearing out any ssh screwups, addons, or rootkits if a device got compromised (ie by leaving ssh port open with a weak password).
yes I understand that some addons use /c/addons to store information on the data volume, but if the system were erased and returned to default, no custom addons would be installed or loaded on the system partition and thus also avoid having a broken addon being loaded from the data volume.
