TeknoJnky
Jan 10, 2011Hero
wishlist - ultra 2/4/6 with sandybridge and hdmi
I want an ultra with an intel sandy bridge system and hdmi out. Sandy bridge has integrated video on the cpu that is actually pretty powerful. Why? An XBMC server.
mjw1
Mar 04, 2011Aspirant
TeknoJnky wrote:
viewtopic.php?f=19&t=51208
under all circumstances (i.e. even for doing a Windows directory copy that contains lots of smaller files). The Ultra 4 can only manage about 14 MB/s
I think its highly dependant on the disks.
Interesting to see your performance results in the thread you referenced however I notice that although these numbers exceed 100MB/s you are mostly copying large files (movies, music) and also you seem to be measuring the aggregate performance across multiple concurrent reads. Is that correct? I would expect that if you did the same test with a single user process copying thousands of 4K files you would get much lower than 100MB/s.
For example, if you look a the results for the WD20EARS drives that you use in your NAS, the 4K read/write performance is less than 1MB/s! Here is the worst-case performance of a single disk. You should get higher performance with 4 disks in RAID-5 but not 4 times the performance:
So, I think there is a lot of potential performance benefit by adding an SSD cache like the Vertex 3 that can approach 70MB/s for a 4K read (which is over 100 times better performance than possible with a WD20EARS drive).
and 200MB/s for a 4K write:
