blkgato
Nov 04, 2015Aspirant
X-Raid or Flex
I have two drives in my system and would like to have them show as two drives and not as one or mirror. This way if I have 4 - 4GB Drives I can have each one set up for different data. Thank you
Hi there,
for this set up you need to destroy the volume, disable xraid and recreate a new volume in flex-raid. Then you can decide how many disk you want in the volume.
My raccomandations is to have the nas using the default value to prevent data lost. Disc have moving parts and subject to waer.
Regards
needhelp
- cpu8088Virtuoso
"""My raccomandations is to have the nas using the default value to prevent data lost. Disc have moving parts and subject to waer."""
raid is for redundancy. not a proper backup.
Yes that is right, infact the default value of XRAID enabled is there to prevent uncorrected volume creations and give yo a peace of mind out of the box. From the name you can gather the key ReadyNAS... which mean put it in the network and if you are not so savvy you can use it straignt out of the box. So if you are in Flex raid and use all the disk in R0 you are risking your data. I never said that having that setting was a backup.
Backup now a days should be second nature. It is unacceptable that after all this time of digital life people are still not backing up.
- blkgatoAspirant
Thank you for the reply. I am in Flex-Raid but it won't allow me to format or create a new volume. Am I doing something wrong?
- mdgm-ntgrNETGEAR Employee Retired
You would need to backup your data and destroy the existing volume before you can create new volumes.
To create a new volume you would follow the steps in this article: http://kb.netgear.com/app/answers/detail/a_id/23131/~/how-do-i-create-a-volume-on-my-readynas-os-6-storage-system%3F
