kiwi1969
Oct 31, 2011Aspirant
xterm-256color support on NV+
Hi, I was trying to get around this since OSX Lion defaults to $TERM=xterm-256color One workaround posted somewhere, was to configure Terminal in OSX to use xterm-color when connecting to the Read...
kiwi1969
Nov 25, 2012Aspirant
You will also need to edit .bashrc to enable the colors (lines already exist, just need to be uncommented)
The next login will then be colorized.
You will need to redo this each firmware upgrade!
export LS_OPTIONS='--color=auto'
eval `dircolors`
alias ls='ls $LS_OPTIONS'
alias ll='ls $LS_OPTIONS -l'
alias l='ls $LS_OPTIONS -lA'
