jogyth
Oct 07, 2017Tutor
Your NETGEAR storage is not accessible from this computer... ReadyNAS Duo
Hi! I've been around this forum for the last couple of hours - but I could not find my fix. Appologies up front if it has been answered before - but the thins is that I'm just a regular consumer an...
- Oct 09, 2017
jogyth wrote:
or temp rig my local network to use the same range so that I can access the admin page at least?
Yes. An easy way is to set the LAN address range of your router to 192.168.86.x. Then reboot the router, and (if needed) the PC. Then you should be able to get to the admin page, and reset the IP address to DHCP.
Though there is puzzle here - your win7 PC shouldn't have been able to reach the NAS either.
jogyth
Oct 08, 2017Tutor
Can't remember setting it to a static IP.
The procedure did not work I'm afraid. Same IP.
Come to think of it - the unit was connected to the network at my office for a little while. It's a small and very controlled network. It could have been set to a static IP by my tech guy there alltough I do not remember that to have been a subject of conversation. Mind you - I'm over 40 so I don't remember all conversations from the past very well ;-)
Any way to force it to release that IP - or temp rig my local network to use the same range so that I can access the admin page at least?
Oct 09, 2017Guru - Experienced User
