andyask
Sep 14, 2012Guide
#19436397 5.3.6 ARM-Unable to use ReadyNAS remote
Hi Duo V2 Since upgrading to 5.3.6 users have been unable to access log into the NAS via ReadyNAS remote. I get "ReadyNAS Remote Online - Andy Asker" but it never actually connects to the serve...
mdgm-ntgr
Sep 16, 2012NETGEAR Employee Retired
1. It should however it seems your Remote install is messed up.
2. I think in the Mobile apps the list of Remote NASes caches the list so even NAS units that are offline will appear
3. Not turning on due to a messed up configuration
4. Take a look at the YouTube video embedded in my post above. In it Jeff explains ReadyDROP. It's a new feature that relies on ReadyNAS Remote. You can choose whether or not you wish to use it.
5. Yes, send him a PM. If enough users have the same problem (note while multiple users may think they have the same problem in reality the problems can be quite different) and it's verified as an issue with the firmware then it would be addressed in a firmware update.
