andyask
Sep 14, 2012Guide
#19436397 5.3.6 ARM-Unable to use ReadyNAS remote
Hi Duo V2 Since upgrading to 5.3.6 users have been unable to access log into the NAS via ReadyNAS remote. I get "ReadyNAS Remote Online - Andy Asker" but it never actually connects to the serve...
bhw752k
Sep 16, 2012Aspirant
Rozel, what you are describing has happened to me as well. It is because we both attempted to manually install the ReadyNAS Remote addon when really we shouldn't have. Here's how I fixed the problem:
Make sure you remove the ReadyNAS Remote addon from the addons section.
Download the 82 MB firmware update file:
http://www.readynas.com/download/RAIDiator-arm/5.3.6/RAIDiator-arm-5.3.6
Go to System > Settings and click the 'Update Firmware' button under the UPDATE heading. Then browse to your downloaded 82 MB file to update, apply, and restart. This will re-install the firmware and hopefully should correct the ReadyNAS Remote conflict.
Then when your ReadyNAS has finished restarting, make sure you reload the Dashboard, bypassing your browser's cache.
I believe ReadyDrop is sort of a Dropbox clone that uses your ReadyNAS in place of the Dropbox servers. ReadyNAS Remote appears to be a prerequisite for using ReadyDrop.
Hope that helps.
Hope that helps.
