andyask
Sep 14, 2012Guide
#19436397 5.3.6 ARM-Unable to use ReadyNAS remote
Hi Duo V2 Since upgrading to 5.3.6 users have been unable to access log into the NAS via ReadyNAS remote. I get "ReadyNAS Remote Online - Andy Asker" but it never actually connects to the serve...
techman05
Sep 17, 2012Guide
akamming wrote: I had the same issues after the firmware upgrade. Symptons vague
- sometimes no remote settings in raidiator
- sometimes they were visible, but no matter how hard i tried turning remote or readydrop on. After a refresh of me explorer age remote sometimes returned to diabled
- often both readydrop and remote did not work (nas unreachable)
I did a manual reinstall of the firmware and then an os reinstall boot menu. Now everything works fine.
Only 1 remaining issue. From the android app only anonymous access is working. I did not try this before the firmware upgrade. So i don't know if this is related. Does anyone know how to solve?
I was thinking on the phone to try to updste your readynas remote app and check before you connect since the new update trys to connect with cifs and not ftp , which either way after loging on you need a userid on the nas and not just remote.
Also though I have a v1 readynas on the pc's been fickle. I had to close it after install and run as admin to improve chance to connect on my win7 PC and my Vista there seems to be a diferent problem with both sayin incorrect username or password. Its better than last update but still fickle.
