hellbent1
May 20, 2010Aspirant
Automatic 0.6.2 on Duo Issues
I've been trying to get automatic running on my Duo for the last few days with little to no success. I'm not much for unix so that doesn't help matters but i'll walk you thru where i've gotten to. ...
hellbent1
Jun 01, 2010Aspirant
okay, did some more playing this afternoon.
I'm assuming that you want me to set transmission-version to "external" since if i just remark out that whole line automatic seems to default to 1.3 (at least that what it looked like in the log).
i've been getting "[getHTTPdata]:number of redirects hit maximum amount" errors when i use the feed url i wanted to so i've setup a feed on mininova which doesn't error like the other for testing. one thing at a time...
I've also setup a filter for ".*" which i'm thinking should download ALL torrents (as a test of course, i've set transmission to ignore the watch folder for the momement).
however, the source folder isn't filling up so i'm assuming either my feed entry isn't right or my filter is wrong...
one other question: where/how is automatic called/started when I enable it from frontview? i'd like to modifiy that command to use my alternate paths for the .conf, .state and log files.
feed = { url => "http://ezrss.it/feed"
url => "http://www.mininova.org/rss.xml" }I've also setup a filter for ".*" which i'm thinking should download ALL torrents (as a test of course, i've set transmission to ignore the watch folder for the momement).
filter = { pattern => ".*" }however, the source folder isn't filling up so i'm assuming either my feed entry isn't right or my filter is wrong...
