hellbent1
May 20, 2010Aspirant
Automatic 0.6.2 on Duo Issues
I've been trying to get automatic running on my Duo for the last few days with little to no success. I'm not much for unix so that doesn't help matters but i'll walk you thru where i've gotten to. ...
hellbent1
Jun 01, 2010Aspirant
Ah, found the start.sh and modified it. that should make testing a lot easier.
i've setup "use-transmission = no"
do you find that the feed or the url works best? i'm not getting any errors based on the logs now but i'm not downloading the torrents to my specified directory either. i'm parsing on ".*" at the moment...
[10/06/01 18:13:35] ../src/automatic.c, 560: ------ Checking for new episodes ------
../src/automatic.c, 573: Checking feed 1 ...
../src/web.c, 401: [getHTTPData] url=http://rss.bt-chat.com, curl_session=(nil)
../src/web.c, 366: [am_curl_init] Created new curl session 0x3b660
../src/web.c, 188: [write_data_callback] allocated 102400 bytes for mem->response->data
../src/web.c, 438: [getHTTPData] response code: 0
../src/automatic.c, 428: [processFeed] curl_session=0x3b660
../src/web.c, 570: [closeCURLSession] Closing curl session 0x3b660
