hellbent1
May 20, 2010Aspirant
Automatic 0.6.2 on Duo Issues
I've been trying to get automatic running on my Duo for the last few days with little to no success. I'm not much for unix so that doesn't help matters but i'll walk you thru where i've gotten to. ...
veehexx
Jul 25, 2010Aspirant
same issue as OP -
whocares - you mention not to use the rpc method, has this been fixed in the lastest 0.9.3 release or still has issues? (i'm using 0.9.3 - not sure if it's RPC having known issues, or me!)
edit: now i've moved to .torrent file, im getting the following error with 'automatic -f -v 3' via ssh
i've confirmed the 6 torrent files are being saved in the stated location. also they get added to transmission sucessfully to. so im not quite sure why the above error is happening.
../src/web.c, 523: Upload to 'http://localhost:8181/transmission/rpc' failed: number of redirects hit maximum amount
../src/web.c, 95: Content-Length: 7625
../src/web.c, 438: [getHTTPData] response code: 0
../src/file.c, 95: Saved torrent file '/c/media/BitTorrent/sources/[filename].torrent'
../src/state.c, 66: Saving state (6 downloaded torrents) to disk
../src/state.c, 68: Error: Unable to open statefile '/c/addons-config/Transmission/transmission-daemon/torrents/' for writing: Is a directory
../src/list.c, 228: [cleanupList] size before: 6
../src/list.c, 239: [cleanupList] size after: 0
../src/web.c, 570: [closeCURLSession] Closing curl session 0x3b1a0
../src/automatic.c, 578: New bucket size: 62
