hellbent1
May 20, 2010Aspirant
Automatic 0.6.2 on Duo Issues
I've been trying to get automatic running on my Duo for the last few days with little to no success. I'm not much for unix so that doesn't help matters but i'll walk you thru where i've gotten to. ...
Andreas75k
Aug 24, 2010Aspirant
Andreas75k wrote:
WhoCares? wrote: Basically the script shouldn't try to move more than one file at a time.
Try changing the "mv" into an "echo" and let me know what the output is.
-Stefan
I get this: testdocument testdocument.torrent
Problem solved, all I had to do was to add some quotes on the filenames in the mv command.
Thanks again for your help!!
