hellbent1
May 20, 2010Aspirant
Automatic 0.6.2 on Duo Issues
I've been trying to get automatic running on my Duo for the last few days with little to no success. I'm not much for unix so that doesn't help matters but i'll walk you thru where i've gotten to. ...
Andreas75k
Aug 26, 2010Aspirant
Kevin_R wrote: When using automatic to download the torrent files, they're saved with strange names such as FGR4RF~2 etc
Using the dir command within the directory the files are saved in returns a list of real torrent names, for example torrent.one.name.torrent and not the strange names listed above.
However, both transmission and the rename script in this thread see the files as the strange names, so I can't rename them to .torrent files or get them to auto-load.
Anyone have any idea why this is occuring?
Thanks!
Did you try adding the quotes in the script? That worked for me, and I get the same strange filenames.
Here is the code I used:
#!/bin/bash
cd /c/media/BitTorrent/Sources
for file in *; do ext=${file: -7}; if [ ! "$ext" = "torrent" ]; then mv "${file}" "${file}.torrent"; fi; done
cd -
