hellbent1
May 20, 2010Aspirant
Automatic 0.6.2 on Duo Issues
I've been trying to get automatic running on my Duo for the last few days with little to no success. I'm not much for unix so that doesn't help matters but i'll walk you thru where i've gotten to. ...
Kevin_R
Aug 26, 2010Aspirant
I still have the same issues, even after adding quotes.
I can create a file manually, using a similar name and the script will rename it without any issues, it's only files created by automatic that it can't rename!
Nevermind, it seems the quotes did it. Even though the file names look the same as they did originally, Transmission recognises them as torrents and auto-loads them! :)
Finally, where is the best place to use this script? Should I just set it up as a cron, or place it into the automatic start.sh script?
Cheers!
Cheers!
