hellbent1
May 20, 2010Aspirant
Automatic 0.6.2 on Duo Issues
I've been trying to get automatic running on my Duo for the last few days with little to no success. I'm not much for unix so that doesn't help matters but i'll walk you thru where i've gotten to. ...
btaroli
Oct 22, 2010Prodigy
As it happens, I've also bumped into this redirection message. I did pull a source copy of automatic, but haven't had to time yet to trace down the actual culprit here. I suspect it's the RPC step to transmission since I can successfully get automatic to write torrent files to a watch dir. Problem is that the latest transmission add-on versions seem to not support the watch-dir function, despite having entries in the default config file (sigh).
So, either way I am still hunting a working solution.
