hellbent1
May 20, 2010Aspirant
Automatic 0.6.2 on Duo Issues
I've been trying to get automatic running on my Duo for the last few days with little to no success. I'm not much for unix so that doesn't help matters but i'll walk you thru where i've gotten to. ...
WhoCares_
Oct 22, 2010Mentor
If you're looking at the code using a recent Linux distribution it's unlikely you'll find a problem. Many of the problems with automatic on the Sparc line of ReadyNAS systems relate to old versions of Curl, PCRE and other libs used on the ReadyNAS. One of the things is that cURL on the Sparc ReadyNAS will return the actual redirect http status code (30x) whereas newer versions of cURL return 200. Automatic in it's original version will check for a 200 status and thus will never ever work on Sparc ReadyNAS systems without being patched ;)
-Stefan
-Stefan
