hellbent1
May 20, 2010Aspirant
Automatic 0.6.2 on Duo Issues
I've been trying to get automatic running on my Duo for the last few days with little to no success. I'm not much for unix so that doesn't help matters but i'll walk you thru where i've gotten to. ...
btaroli
Nov 30, 2010Prodigy
Oh, by the way. For those of you using Automatic with TVTorrents... there is a MUCH easier way to set up includes and excludes now. They have a "mytaggedRSS" feature to replace the standard "favorite" RSS feed. This new features offers "include" and "exclude" parameters that can be used to wildcard filter the feed /before/ your RSS client (including Automatic) sees it.
So I've converted mine to this and have been able to simply use a filter of ".*". Upshot is that if you want to do different cuts of filters, you simply specify multiple feed URLs with different parameters. And if you want to apply those filters to specific shows, you merely apply the tags (in TVTorrents' site) to just those shows.
VERY handy, and makes using Automatic even more... automatic! ;)
